Get all designs on same plane
techXSJ4J
techXSJ4J
Community Visitor
Community Visitor
I loaded a design that someone else made from Tinkercad to 3D print. However, the whole design does not sit all the way flat on the plane. If you notice on the right object, some are taller than the rest and one sits lower. Most of them are in the air. The left object sits halfway through the plane. It's all loaded as one file so I'm not able to adjust each object individually to get it on the plane. Any advice on how to do that?Screenshot 2022-03-02 095752.png
jhackney1972
Please attach the model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
hamid.sh.
That's a mesh, and a very simple design to create from scratch using Fusion's solid modeling tools. It should take 5 minutes to do so.
That being said, you can probably use Mesh > Modify > Separate to separate mesh shells:
Hamid
