Message 1 of 12
- Mute
- Permalink
- Report
Hi all,
The problem seems trivial, but I am a complete beginner, and cannot move forward.
I have two preservative geometries which I want to connect with a starting shape in order to give a more desirable result. Without the starting shape, the previewer can run without a problem. (See no-starting-shape.png)
When adding the starting shape, which is a hollow body build from a 3D-scan of a leg, the previewer fails. (See w-starting-shape.png) The starting shape is cut with the the perservative geometries, and meets the surfaces perfectly.
Let me know if more info is needed, and thanks in advance.
Best,
Edvin
Autodesk Fusion 360 (2.0.7421)
Windows 10 (1909 18363.628)
