Fusion360 CAM simulation not working
JJackrabbit
JJackrabbit
Hi
I've got some big issues with Fusion360 and CAM simulation.
It always worked perfect without issues.
I don't know what triggered this issue but I'm unable to perform a cam simulation.
For simple 2D operations it works slow but fine.
But when doing 3 axis or 4 axis work it just freezes
I think it has something to do with the stock calculation. When I turn off "stock" in the simulation dialog I can atleast see my toolpath and the cutter moving in the part. I just don't see stock.
When I turn on stock Fusion freezes and gives me maybe 2 seconds of simulation before freezing again.
I've already reinstalled Fusion without any effect
ps: I think toolpath generation takes longer than normal.
Running a Windows 11 Asus TUF Gaing FX506 A15
AMD Ryzen 7 4800H
GeForce RTX 2060
16GB RAM
SSD
seth.madore
What is your Accuracy set to?
Your computer specs are better than mine, so I don't think it's hardware related
If you're trying to simulate while In Process Stock is calculating, there is some definite lag. Is that the case? 
Seth Madore
JJackrabbit
Hi Seth,
Ow it was that easy?
The accuracy was maxed out. I lowered it and I can simulate CAM now 🙂
Thanks for the quick reply and help
Have a nice day
