Fusion wont load
Fusion wont load
fishertalman
Message 1 of 16
Fusion wont load
fishertalman
I have the individual version of fusion 360. As I load into it I am met with the main screen and at the bottom it says "checking your account". the top left says "expired subscription, read only".
What do I do to fix this. Could my computer just be too slow?
Replies (15)
Message 2 of 16
RajkumarIlanchelian
@fishertalman Are you able to login to https://login.autodesk360.com/login ?
Can you tell me if you are on windows or Mac?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 16
fishertalman
Yes I am able to login into that. I am on windows
Message 4 of 16
RajkumarIlanchelian
@fishertalman
Please try below steps.
1. Make sure that Fusion is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folder – Identity services,
3. Now start Fusion and login again.
Does that help?
Autodesk Fusion
Join Fusion Insider
Message 5 of 16
fishertalman
I deleted the folders and ended Fusion in task manager. Im still stuck on the same screen though. The main page that wont let me close fusion unless I do it from the task manager. I deleted and reinstalled fusion before because it was doing this.
Does fusion launcher have to be in a specific folder?
Message 6 of 16
RajkumarIlanchelian
@fishertalman Lets reset here
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Autodesk Fusion
Join Fusion Insider
Message 7 of 16
fishertalman
Okay I did that, Do I sign in immediatley?
Message 8 of 16
fishertalman
I believe I dont have the web services folder at all
Message 9 of 16
RajkumarIlanchelian
@fishertalman You can clear the entire Autodesk folder and then go to the next steps.
Autodesk Fusion
Join Fusion Insider
Message 10 of 16
fishertalman
I did that and installed it again. I loaded it up and get stuck on the same screen.
I went to those files and couldn't find the web services folder.
Message 11 of 16
RajkumarIlanchelian
@fishertalman
can you please check the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AdskIdentityManager.exe\Debugger - if it's there and if it has the value "Blocked", remove that registry key
If the above does not work then can you collect logs for me?
1. Go to add/remove program
2. Select Autodesk Fusion - modify
This will launch the Fusion service utility
3. Run gather system info
4. Attach the Fusiondiagnosticslogs.zip
Autodesk Fusion
Join Fusion Insider
Message 12 of 16
fishertalman
The "AdskIdentityManager.exe\Debugger" part of those steps isnt there.
I try to launch the fusion service utility and it tries to launch for three seconds and crashes
Message 13 of 16
RajkumarIlanchelian
@fishertalman This is interesting.
Can you please try the below?
1. Go to this article
2. Run the section " Check if the web browser is blocking Autodesk Identity Manager"
Autodesk Fusion
Join Fusion Insider
Message 14 of 16
fishertalman
Im sorry but I dont know how to do that
Message 15 of 16
RajkumarIlanchelian
@fishertalman @What is your default browser ?
Autodesk Fusion
Join Fusion Insider
Message 16 of 16
fishertalman
I use google chrome
