Fusion window comes out of fullscreen when opening Data Panel
alundRQ4XG
alundRQ4XG
My fullscreen Fusion window recently started coming out of fullscreen any time I open the data panel. My window automatically resizes to just slightly larger than fullscreen (the very edge of my window bleeds off the screen), even if my window was set to a smaller size prior to going fullscreen. I'm on Windows 10 Pro, build 19045.4529. My Windows 11 PC at home doesn't seem to have this issue.
lance.carocci
Hi @alundRQ4XG, I was not able to reproduce this on my devices, but it could come down to graphics and display configuration.
Can you tell me more about the device exhibiting symptoms? For example, number of displays, layout within Display Settings, DPI scaling of each display, GPU model and driver date/version. A DXdiag report also contains this, should you wish to attach that after editing out any personal information such as usernames.
I do know that the issue of Fusion reopening as a large window rather than maximized will be fixed in an upcoming release, and that may be related to this experience.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
alundRQ4XG
Thanks for the response @lance.carocci! Here's a DxDiag report.
chylld
I am having this issue too, on a secondary monitor with Windows scaling = 100%.
Notably, this is different from the primary monitor's 125%.
Processor 12th Gen Intel(R) Core(TM) i7-12700H 2.30 GHz
Installed RAM 40.0 GB (39.7 GB usable)
NVIDIA RTX 3060
Edition Windows 11 Home
Version 23H2
OS build 22631.3880
dtstock5
Observer
Observer
I would like to extend this issue.  I use 3 screens.  When Fusion starts, the window starts on the main screen almost full screen.  The first thing I do is stretch the window to have the Data Panel on the left screen, the main on the center screen, and the cube on the right.  I would like to save this view with a new View command like "Save Current view", or automatically save the view/layout automatically when closing Fusion.  It would save only a minute on startup but would be convenient.
