fusion will not start after removing sql
Message 1 of 1
Fusion does not list SQL as a dependance to operate. The only thing that changed on my laptop is I removed SQL 2012. When Fusion starts I see the launcher.exe start in background processes, next the fusion 360.exe will start. shortly after the processes change to the Apps section of the task manager I get the pop up to submit a report. I have removed and reinstalled, fusion, I have started windows in safe mode and same symptoms. After booting again in normal mode I was following the process to remove the loginstate.xml file. After removing the XML file next time I launched it I got the login prompt. I logged in normally and then it kicked out to the error again. I watched the dispatch service launch for a split second in the task manager and immediately I get the request to send in the report to Autodesk.
the only responses I get from the automatic solutions are very generic that I am running out of resources.
I have attached the dxdiag file and the last startup logfile from fusion. along with a complete file list included with the crash dump to Autodesk.
last little bit of the log file is as follows;
20200207T130506 E Current thread ID: 13164
(module:ntdll) File: (filename not available): NtWaitForAlertByThreadId
(module:ntdll) File: (filename not available): RtlSleepConditionVariableSRW
(module:KERNELBASE) File: (filename not available): SleepConditionVariableSRW
(module:MSVCP140) File: (filename not available): _crtSetThreadpoolWait
(module:MSVCP140) File: (filename not available): std::_Syserror_map
(module:MSVCP140) File: (filename not available): Cnd_destroy
(module:NsCloudFileStore10) File: (filename not available): Ns::CloudFileStoreDownloadEvent::json
(module:NsCloudFileStore10) File: (filename not available): Ns::UploadQueuedFileInfo::version
(module:ucrtbase) File: (filename not available): o_exp
(module:KERNEL32) File: (filename not available): BaseThreadInitThunk
(module:ntdll) File: (filename not available): RtlUserThreadStart
20200207T130506 E Total thread counts is 62
20200207T130506 E Current Document/Asset information is as following when program got crashed:
There is no active document
20200207T130506 E The recent operations of commands/requests are as following:
Replies (0)
