fusion sweep parallel error
inflameWBW5X
inflameWBW5X
I am trying to create a milling tool path using the sweep command.
The circle represents the cutting face of a 3mm flat end mill.
For some reason the program doesn't like the parallel orientation ?
Any idea how to fix this ?
davebYYPCU
Designing or Manufacture question?
Screams to me to be a self-intersecting request.
What are you expecting to happen at bottom dead centre? (Zoom In)
I can get a Sweep Body to half way, and then mirror the feature.
Might help....
inflameWBW5X
Thanks for the answer.
Yes design mode.
I tried half way sweep with intention of mirroring but it didn't work for me. What settings did you use ?
PS oh wait.  You used a body. Is that a body sweep ?
I've never tried that.
inflameWBW5X
Yep got it , thanks.
Had to set "parallel" to get it in one go.
Cheers
