Fusion shutdown issues
l_dowell1117
l_dowell1117
Is anyone else having shutdown issues with Fusion? This is regularly happening on a couple of machines. I'll close a project, it closes and uploads to the cloud. Then I close the program and it just hangs. If I attempt anything else in the window I get a 'not responding' message. I can hit the Fusion 'X' close and Windoze will ask me if I want to close and I'll let it. I can use task-manager as well. Once as an experiment I left my home machine in that state, went to work and opened Fusion there. It opened fine so the 1st session had logged me off. Got home 8+ hours later and that machine was still trying to close.
I can't say this happens every time I close, but I have come to expect it. If I open the program and make no edits it closes fine. If I make an edit but don't save, no problem. If I make an edit and save, the problem appears. I have done a cache clear, no change. I will try a repair/reinstall but I'd like to see if there is something else going on before doing so.
Lyle D
tasha.addington-ferris
Autodesk Support
Autodesk Support
Hey @l_dowell1117 , this sounds like the same issue as another thread which is already engaging with our development teams:
https://forums.autodesk.com/t5/fusion-support-forum/fusion-won-t-close-freezes-up-after-the-update/t...
Tasha Addington-Ferris
Autodesk Fusion
Prerelease Supportability Engineer
