Fusion refuses to extrude the RomanT capitol "U"
pwrlineman
pwrlineman
I recently tried to extrude some text(RomanT), and every letter in my sketch cut except the "U". I really don't know what I'm doing , so I was sure it was my mistake somewhere, however I've created a new sketch and found the problem repeated itself. How/Who do I notify of this potential glitch?
jhackney1972
Please attach your model to a reply post.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
jhackney1972
As you can see I do not have an issue with a RomansT "U", at least a capital letter.  This is why we need to see your model.
pwrlineman
That's interesting... Before you replied, I was reading suggested threads. I decided to explode my text. After reading your post and wanting to sent model, I went back to find that I don't know to return my text.... Here is a screenshot of the u and U on the same sketch, only the u works. Screenshot 2021-11-24 183147.jpg I was able to work the exploded text as I wanted, at least after clipping a stray loop off of the U.
pwrlineman
Extruding the U on this cube fails as well.
pwrlineman
Could this loop shown here on the exploded text cause the failure I was experiencing?extra lines on the exploded U.jpg
jhackney1972
Sorry, I was called away.  The indicated loop could definitely cause the issue.  I did not experience any issues with your model though, it is attached.  I used my Windows installed RomanT font so I am thinking yours may be corrupt.  I have exported my font and included it along with your modified model.
