Fusion not working when connected to Home Network
martin.schweinzger2MA2B
Observer Observer
Observer
Observer
I am currently having trouble using Fusion when I am connected to my home network. It takes ~5-10min to even start and when it is finally loaded everything that involves the cloud (like saving a file, exporting a stl...) freezes the program and takes minutes until it is available again (also the actions fail most of the time). I tested using Fusion connected to the hotspot of my phone and everything works fine. I am not sure what is causing this problem since I haven't changed anything in my network and it worked fine until a few weeks ago.
Does anyone know what might be the reason for this problem. Are there some settings on the network or Laptop (16" Intel Macbook Pro) that i have to check?
I would appreciate any help
Phil.E
Thanks for posting.
Can you please try the Fusion Service Utility, network diagnostic test?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Overview-of-Fusion...
Let me know what it finds, glad to help.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Observer
Observer
I just tried the network test and found that there apparently is something wrong
 I went to the website linked on "learn more" and added all the required domains listed into the network settings, but it doesn't seem to change anything
Also I tried the linked proxy detector and got the following result:
It says that I do not use proxy, so I am confused what this now means, since I am not that educated on networking stuff
Phil.E
Thanks for checking.
If you could please do the following:
1. Start Fusion
2. Wait the 5-10 minutes
3. Gather diagnostic logs
4. Send to me in a PM or to phil dot eichmiller at autodesk dot com
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Phil.E
Thanks for the logs. Sorry I was unable to return to this post until today.
I've sent this to our developers for further analysis. I do see some unexpected entries in your logs, but the results are known errors. We just have to figure out why it's happening like this for you.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Phil.E
The logs show a low performance network connection. Can you please try speedtest.net and let me know the results?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
mykhailo_mushynskyi
Hello Martin,
Thank you for reporting the issue.
From the logs you have sent, it looks like you have problems resolving web addresses of our services. It might be a problem with outdated DNS cache from your internet provider.
I suggest temporarily switching a DNS server (instruction for macOS) and see if it helps. You can use any public DNS you prefer. Some of the popular solutions are Google Public DNS and CloudFlare DNS Resolver.
Important: If you have other DNS servers already listed in Network settings, make sure to back up their addresses as you might want to switch back to them later.
