Fusion not starting up on Mac OS 15.3
murray_miskelly
Message 1 of 14
murray_miskelly
I am running Fusion on a MacBook Pro. (I am the only user on the machine, and am the administrator)
After install I can run the app once, and then if I quit the app it won't initialise again.
The icon appears in the dock to say it is initialising, but immediately the 'active dot' disappears. I get the same occurrence when trying to run the Service Utility.
I am on the latest version of Mac OS, and I have fully restarted the machine and still see the issue.
I followed the AutoDesk Assistant suggestions and  deleted the suggest .dat file from the application Support folder, but that did not appear to make any difference.
Any further suggestions?
Replies (13)
Message 2 of 14
RajkumarIlanchelian
@murray_miskelly If you go to launchpad and find Fusion and launch Fusion from there, does the same thing happen?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 14
murray_miskelly
Same result.
Could it be a permissions thing maybe?
Message 4 of 14
murray_miskelly
Another symptom. When I run the installer and it opens Fusion there is an additional app icon in the dock (see attachment 1). If I trace that back it is running from within the 'webdeploy' folder from within Application Support where the app is 9GB in size (attachment 2).
In my Application folder in the Autodesk Fusion folder there are three icons for Fusion, Service Utility, and Remove Fusion, all less than 200k in size (attachment 3). Is this the normal install?
Message 5 of 14
RajkumarIlanchelian
@murray_miskelly what yo see are all normal. Lets try a couple of things.
1. First we need log files but since Fusion service utility is not working lets collect the THREE logs manually - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-manually-co...
2. Quickly create a new user on this Mac and install Fusion. See if the same behavior happens.
This will start to give us some direction what could be happening.
Autodesk Fusion
Join Fusion Insider
Message 6 of 14
shane_huston
Community Visitor
Community Visitor
I am having this exact problem. I have to reinstall Fusion every time I want to launch it.
Message 7 of 14
shane_huston
Community Visitor
Community Visitor
Ah, I went to Launchpad, noticed there are two Fusion 360 icons and two icons for the 360 Service Utility. I tried both and one of them worked.
Message 8 of 14
RajkumarIlanchelian
@shane_huston Here is a way to clean it all up.
  1. Logout and Close Fusion
    2. Go to Launchpad - Uninstall Fusion
    3. Go to Users - YOUR USER ID - Applications - delete all the Fusion icons you see in here (you should see two Fusion icons and two service utilities etc)
    3. Go to
  • Macintosh HD>Users>(username)>Library>Application Support>Autodesk>Autodesk Fusion 360>
  1. DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
  2. Delete the Fusion launch icon (from desktop or where you have it)
  3. Restart the Mac
  4. Download the installer again
  5. Now install Fusion
Autodesk Fusion
Join Fusion Insider
Message 9 of 14
murray_miskelly
Rajkumar,
The requested logs are attached as a zip file, hopefully they will come through.
I have created a new user and re-installed Fusion. It behaves correctly in that space so obviously it is something clashing with my user.
Good luck...
Murray
Message 10 of 14
mt125136343F
Community Visitor
Community Visitor
Same issue
Message 11 of 14
RajkumarIlanchelian
@mt125136343F Does any recommended solution called out in this thread help?
Autodesk Fusion
Join Fusion Insider
Message 12 of 14
pirey4
For the past month or so I have been having the same issue where I have to reinstall Fusion 360 every time I want to use it.  Prior to that, everything worked fine and I could restart Fusion 360 without having to reinstall it.  Now I'm having an additional problem.  After trying the 8 steps that @shane_huston suggested above to clean up the install, I can't get past the login screen at the end of the install.  It says "A browser window will open for you to sign in.  If you can't find the browser window, retry browser sign-in.".  A web browser page didn't open automatically so I manually opened Safari and logged back in but Fusion 360.  When I restarted Fusion 360 after logging into the browser first,  it opened Safari to the last tab I was on (where I logged into the Autodesk site) but Fusion 360 never starts. It keeps telling me to "Retry browser sign-in".
Message 13 of 14
pirey4
After rebooting a second time, (the first time was in Step 6 above) I was able to log in.    I'll report back if I continue to run into the issue where I can't start Fusion 360 without re-installing it.
Message 14 of 14
murray_miskelly
Good morning Rajkumar, I'm just wondering if there had been an update on looking at the app logs that I sent through?
Cheers,
Murray
