Fusion Not opening Maximized
So every time i launch fusion 360 it opens on what windows calls "Restored Down". Not minimized or maximized, but floating. It leaves like a 1/4 in of my wallpaper showing one side or the other.
    Is there any fix to this? Or is anyone else having this issue?
julia.paganucci
Autodesk Support
Autodesk Support
hi @Anonymous ,
thanks for posting! Was fusion maximized prior to restarting? Are you using windows 7 or 10? this is logged as FUS-49311.
thanks,
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
bbratus
The same is happening to me. When I open Fusion 360 it doesn't launch maximized. If I then manually maximize the window and close the program, the next time I open Fusion 360 it actually will launch maximized, but on the second attempt it will again launch not-maximized.
I have also tried selecting the option to force maximized launch under shortcut options but it does not solve the problem.
The same problem was described here, so it looks like that the problem has been noted, but nothing has been done to solve it so far: https://forums.autodesk.com/t5/fusion-360-support/maximized-window-since-april-update/td-p/8718732
It is not the most critical problem, but it is kind of annoying to have to manually maximize the window every time when opening Fusion.
jwor9031
Also happening here.
dismayer
Community Visitor
Community Visitor
Almost 5 years later and still the same problem appeared after latest update. Is it really that difficult to make it start maximized?
rtopz
same issue here, constantly opens up on 2 machines almost maximized, but not fully maximized.
