Fusion not installing in Windows 11
eautodesk7AH5A
Observer Observer
eautodesk7AH5A
Observer
Observer
Running on Windows 11 - 22H2.
Attempting to do a fresh install of Autodesk Fusion and receive the following error:
Viewing the installation log, it is reporting that it cannot find a specific file. I've disabled Windows Defender during the installation but was unable to get it work.
Below is the log:
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001FA957B8E50> #
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\WINDOWS\TEMP\7zSCDAC.tmp\resources\buildinfo.json
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240201094011
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\WINDOWS\TEMP\7zSCDAC.tmp\resources
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\WINDOWS\TEMP\7zSCDAC.tmp\certs.pem
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000001FA9579BCE0>, operation=<function multiple_operate at 0x000001FA94E885E0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='file:///C:\\WINDOWS\\TEMP\\7zSCDAC.tmp/_payload/', update_connection=None, stream='production', globalinstall=True, no_auto_launch=False, no_uninstall_registry=False, install_origin='Admin', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is True <<<<<<<<
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/
2024-04-01 16:49:26,266 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-04-01 16:49:26,380 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-04-01 16:49:26,662 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Program Files\Autodesk\webdeploy\meta\registry_track is created.
2024-04-01 16:49:26,664 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-04-01 16:49:26,664 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-04-01 16:49:26,664 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Skipping pre-checks. Found environment variable SKIP_PRECHECK OR Admin install.
2024-04-01 16:49:26,665 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-01 16:49:26,665 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f7a6f4a289729f/full.json
2024-04-01 16:49:26,688 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:26,688 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:26,688 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:26,767 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-01 16:49:26,767 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f7a6f4a289729f/full.json
2024-04-01 16:49:26,784 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:26,784 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:26,784 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:26,800 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is c79c6be7-3742-4721-b960-c8f81a954138
2024-04-01 16:49:26,816 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.18719 for app 73e72ada57b7480280f7a6f4a289729f
2024-04-01 16:49:26,816 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 7886a34aba42a6e4df57abdd1795de97364374df detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 0fba9483ecaabd2f40b7f40e13ed19e05fbdf046 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1e484b55a8f9921f1b299d18e590cd7f2cfdba92 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5c7fa680458a5ac72b059788239110275d34fcf0 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk da44a78f54fec34ed4e7fdc4d2e25df6999764ec detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk dad2b2567e643c384d6e88edc9533b716625000a detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 80046041ba124b08a40d8edb55b113c4653447e3 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e84cc9403df05c383dd0447cead59ba84c2c27af detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 8ccc3847e3d228c73cbcde46e353df88302449d9 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 8a0f507ebb5cc55cef8af105a73e14823248ae1b detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c962ac0be676360d42559f336c5e6f35b2e79ee8 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1522c12261f13865df9b1573b0942038ba1a7081 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk ce4a118af44b5a0b760d652f9232ff7b604b3427 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 416ee6c1c8e0dc59bd879cb9c3d869a87503d819 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 69a869de7436e9e6e228a3274ff677a1c566081a detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5eb15a26d6f9148933206443ac74562b2c1e5e1e detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 17da5ebb79f32101a8a44367d7dc975e67d9f2e0 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk d1a57d11087f44520769277ea8c4f9437d86d91d detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 57a75bb1238af1a384aeffbeb8f951eb2d8d3ed1 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6fc05372ce172348fac3949fb36854cde62dcb9b detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 2353d9829f56427f8d23cc00ff53cd38d641d3f8 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 3151c94b3474d5ab5250986f0fd384b821519485 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk db1091095ed1b6a6d4dde75376260b9f8df09b82 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 9354edadfd5afadc188c695dc169b4c6d4e7821a detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 104d7bd8f707c459a75f7d0d2966ff5fac423e4a detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 14691e5674e6cf03c9bf6e06d8c61108a6ebe693 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b38d5a86bef903bd5a524b367895f0c3c6bfbedb detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f5d20840370a61a6de1a69b2dbcdd7c12862bc3b detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5ffa30372eee34a0d5e62791b0e4daf3aeeceecd detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f9f1e3dd5c44a6156f37fd965feab86ea0d5420f detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk a43ab46adde7f3220b2a66a8e69b30c7e6388f31 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 3fd5a745b2f6e709acd29609376e935f1a0333e1 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 17e55912af2afefad66f30ecd478668d00a4a4d6 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e45044ee0440e2122ed4f8da28f82c8f34cfcb1c detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 7e638b3beabf84cdeeca2b87b7934813dd653da9 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 73c592c74ab19b6ca3e301a07569f7497b02d380 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c2dfd07d8c14ad72a960b2989500648ea21ca4dc detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c3dd37c410bc4a0213155711a9e65ddc846eb6ab detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b20e3c55ccfc9e4dac37fbee4721bd88c42b19c2 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 4924fb9ff0c1ec5fe97de7682d68bb7907309962 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 650ed6b47a09360a5ce6b043184c91513ba12f05 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 829f8a0ea3cb429b831cd7cd8ff71f4a7d05c6a1 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 728e0f9ba00cbf429a9b693778af51cd4e18ff98 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 4490dc834f2df5bfd9bde6fead2fdab46525e62b detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cd398d360d746179da04a19fe608256034f75a64 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk db3a70918724349831cd01d3f4ca1e63b01ae7b7 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 47eb308f4e5e99bd73b8431f37a1e9166a17fd08 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 707b02d459df30db8ad51c11c152f0bac7b3ca5b detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 878d67a5642dd04ed113c20f68fe164f2beb9279 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c395c96738f0cdbc46c3150dd055968b1914f98a detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 76e3b8594e9a6e9de6168665ba7638c25b24cefe detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1e964318970e75f6f28f8f4e24ed04607f88730a detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 239ecc749a79bec25e8647fc4c8749b6e3435cdc detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk a1341c70a5e347afd239cdbd014ceeb3749eeef1 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 2c00ef3300cc2cd58ec2f3aa3c4efe646da73872 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1edc6fb6835505d62c3f3819ec066142d9cdbc38 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e44e12388a98d954a16580c62a629f928ce37416 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 33551de9520374f7f3211cddb14a0b54780ef596 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 281ad230054ecde00e75d9d72469bbd8d5bb6a18 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6559056f1b3c028a5e998c0ab70e324cec3fd57d detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk d7d33e101c86b226f5dec957d774577fee3d4fd6 detected on system skipping install.
2024-04-01 16:49:26,880 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1d09c88ca2a62c3958d1475d9df3699eb275bf8c detected on system skipping install.
2024-04-01 16:49:26,880 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-04-01 16:49:26,880 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-04-01 16:49:26,947 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version found.
2024-04-01 16:49:26,947 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2024-04-01 16:49:26,947 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 434a310ba39a5a127daba7317aca946c4aabe839
2024-04-01 16:49:26,947 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/packages/434a310ba39a5a127daba7317aca946c4aabe839.json
2024-04-01 16:49:26,980 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:26,980 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:26,980 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:26,980 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/packages/c2f7fba45e39ef9888fc2fee938315f3ce8e1473.tar.xz for package 434a310ba39a5a127daba7317aca946c4aabe839
2024-04-01 16:49:26,980 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/packages/c5da65df0c9d74d48d5447292f29a3029d9e196f.tar.xz for package 434a310ba39a5a127daba7317aca946c4aabe839
2024-04-01 16:49:27,013 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Start executing tasks thread
2024-04-01 16:49:27,013 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:27,013 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:27,029 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:27,029 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1
2024-04-01 16:49:27,029 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:27,029 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:27,029 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:27,045 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1
2024-04-01 16:49:27,954 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 434a310ba39a5a127daba7317aca946c4aabe839
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action e10f096356f7470ea58e13af02d1ba7c(UPDATE_PINNABLE_LAUNCHER)
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action e11b50c4e45d49c68aa944c2e476a76f(Unknown) was not in registry
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\streamingsession.json
2024-04-01 16:49:28,047 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 7df3ec3a7e8d40ada66494b9dc32dc4e(ACTIVATE_CONFIG)
2024-04-01 16:49:28,094 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Applications\Fusion\Fusion360App\ApplicationOptions.production.xml as \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Fusion 360.server.config
2024-04-01 16:49:28,094 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-01 16:49:28,141 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Applications\Fusion\Fusion360App\ApplicationOptions.us-production.xml as \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Fusion 360.us-server.config
2024-04-01 16:49:28,141 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-01 16:49:28,188 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Applications\Fusion\Fusion360App\ApplicationOptions.emea-production.xml as \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Fusion 360.emea-server.config
2024-04-01 16:49:28,188 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-01 16:49:28,235 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Applications\Fusion\Fusion360App\AdpSDKGlobal.production.config as \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\AdpSDKGlobal.config
2024-04-01 16:49:28,235 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Applications\Fusion\Fusion360App\adpdesktopsdk.production.env as \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\adpdesktopsdk.env
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 8df63efc00a94e9aa262d921a044c83a(PROCESS_TEMPLATE)
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 9a6f9239365141149849b3081dc3fd7c(WRITE_STREAMER_OPTIONS)
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '1' to option 'GlobalInstall'
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Remove option 'DevBuild'
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Cannot get etag because of "'NoneType' object is not callable"
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'production' to option 'InstallStream'
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1341bb4b8566410e9c7c8aef52bcb222(FILE_ASSOCIATIONS)
2024-04-01 16:49:28,376 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-04-01 16:49:28,376 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 4afd20f9b05b4349869fb10841d11444(DELIVER_ICON)
2024-04-01 16:49:28,376 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Deliver the icon of Fusion360.exe to the same folder as the Pinnable launcher.
2024-04-01 16:49:28,392 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-04-01 16:49:28,392 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico stat result: os.stat_result(st_mode=33206, st_ino=3659174697346828, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=177333, st_atime=1712011694, st_mtime=1711026421, st_ctime=1711992228)
2024-04-01 16:49:28,392 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico st_file_attributes: 32
2024-04-01 16:49:28,392 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico stat result: os.stat_result(st_mode=33206, st_ino=3659174697346829, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=40507, st_atime=1712011695, st_mtime=1711026494, st_ctime=1711992228)
2024-04-01 16:49:28,392 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico st_file_attributes: 32
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico stat result: os.stat_result(st_mode=33206, st_ino=3659174697347246, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=39964, st_atime=1712011695, st_mtime=1711026494, st_ctime=1711992228)
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico st_file_attributes: 32
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico stat result: os.stat_result(st_mode=33206, st_ino=4222124650768560, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=39624, st_atime=1712011695, st_mtime=1711026494, st_ctime=1711992228)
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico st_file_attributes: 32
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico stat result: os.stat_result(st_mode=33206, st_ino=3659174697347249, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=39217, st_atime=1712011695, st_mtime=1711026494, st_ctime=1711992228)
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico st_file_attributes: 32
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico stat result: os.stat_result(st_mode=33206, st_ino=3659174697347250, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=38223, st_atime=1712011695, st_mtime=1711026494, st_ctime=1711992228)
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico st_file_attributes: 32
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action abd8ee230bcc49f9a56035b8eefedeed(REGISTER_UNINSTALL) was not in registry
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5ca4357a038540d58fb2092e8a9329a9(REGISTER_SAFE_MODE)
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Program Files\Autodesk\webdeploy\meta\streamer\20240201094011" is found
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Program Files\Autodesk\webdeploy\meta\streamer\20240201094011\streamer.exe"
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - WARNING :: Already installed the latest streamer, do not need to update the streamer
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Create shortcut file: C:\Program Files\Autodesk\webdeploy\meta\streamer\streamer.bat
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Skipping register safe mode. Global Install: True, Skip Register Safe Mode: False
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-04-01 16:49:28,455 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-04-01 16:49:28,455 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 0b9a4c1251914f7facc25616ea0f9de3(CREATE_LAUNCH_ITEMS)
2024-04-01 16:49:28,455 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Create launch items for install
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is launchable. Creating a shortcut
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: destination: C:\Users\Public\Desktop, launchname: Autodesk Fusion
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Trying to rename previous Fusion 360 shortcut if it exists for rebranding live update: from C:\Users\Public\Desktop\Autodesk Fusion 360.lnk to C:\Users\Public\Desktop\Autodesk Fusion.lnk
2024-04-01 16:49:28,486 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-04-01 16:49:28,486 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-04-01 16:49:28,486 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-04-01 16:49:28,486 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-04-01 16:49:28,486 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: destination: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk, launchname: Autodesk Fusion
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Trying to rename previous Fusion 360 shortcut if it exists for rebranding live update: from C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\Autodesk Fusion 360.lnk to C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\Autodesk Fusion.lnk
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-04-01 16:49:28,564 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-04-01 16:49:28,564 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-04-01 16:49:28,564 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-04-01 16:49:28,564 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Exception processing tasks for 434a310ba39a5a127daba7317aca946c4aabe839: [WinError -2147024894] The system cannot find the file specified
2024-04-01 16:49:28,629 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host autodesk.com is accessible
2024-04-01 16:49:28,629 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: *****
2024-04-01 16:49:28,629 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: *****
2024-04-01 16:49:28,827 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: *****
2024-04-01 16:49:28,827 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: *****
2024-04-01 16:49:28,827 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1190, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 95, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1120, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 932, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 1932, in _do_installation
File "R:\src\adsk\dls\streamer\process\process.py", line 1693, in wait_threads
File "D:\Jenkins\3P\PYTHON\3.11.1\WIN64_1\Lib\concurrent\futures\thread.py", line 58, in run
File "R:\src\adsk\dls\streamer\process\process.py", line 1813, in execute_tasks
File "R:\src\adsk\dls\streamer\process\process.py", line 415, in _executetasks
File "R:\src\adsk\dls\streamer\windows\platform.py", line 371, in create_launch_items
File "R:\src\adsk\dls\streamer\windows\platform.py", line 541, in _manipulate_shortcuts
File "R:\src\adsk\dls\streamer\manifests.py", line 807, in walk_external_references
File "R:\src\adsk\dls\streamer\windows\platform.py", line 476, in __filevisitor
File "R:\src\adsk\dls\streamer\windows\platform.py", line 197, in _rebrand_shortcut
File "R:\src\adsk\dls\streamer\windows\platform.py", line 191, in _get_destination
File "D:\Jenkins\3P\PYTHON\3.11.1\WIN64_1\Lib\re\__init__.py", line 185, in sub
File "R:\src\adsk\dls\streamer\windows\platform.py", line 188, in __map
File "R:\src\adsk\dls\streamer\windows\native.py", line 497, in GetKnownFolderPath
File "R:\src\adsk\dls\streamer\windows\native.py", line 761, in GetKnownFolderPath
File "_ctypes/callproc.c", line 1000, in GetResult
FileNotFoundError: [WinError -2147024894] The system cannot find the file specified
Any pointers would be greatly appreciated!
twatson
eautodesk7AH5A
Observer
Observer
To amend to my initial post, this error occurs when ran under the SYSTEM context. If elevated using another administrative account, the installer behaves as expected. Something occurs at the last step of the installation where it fails when ran under the SYSTEM account.
Martin_Saarenkunnas
Same issue here. Have not found a solution yet.
louis_rush
Community Visitor
Community Visitor
Same issue on Windows 11 for us using SYSTEM to deploy. Windows 10 is unaffected.
