Fusion not exporting files error message
giselle.reyes007
giselle.reyes007
I have a simple body I want to export to 3d print and fusion is not exporting it. It either tries to export and freezes or immediately marks it as failed. I'm having trouble with the stl. format and obj. format. A file from yesterday exported, after clicking file/export multiple times.
Internet is working fine, files are saved, no extra symbols on the title. Pretty much the way I have always make them and worked.
jhackney1972
There have been some issues with using the Export command to create STL files.  Try right clicking on the body in the Browser and selecting Save as Mesh command.  It has better options also.
John Hackney, Retired
RajkumarIlanchelian
@giselle.reyes007 Apart from what @jhackney1972 has called out we have heard that trying to do an export the second time succeeded from other customers. We have looked into this issue and we are hoping we can have a root cause fix relatively soon (by the end of the month ??).
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
giselle.reyes007
ah, thanks!
