Fusion non responding after creating machining operations from template
PG.Eng2
PG.Eng2
Try to use a previously saved template for lathe operations that worked before.
After clicking create from template Fusion360 is non-responding.
I have a screencast, which the autodesk forum will not let me add using the insert screencast option because:
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied
Maybe Autodesk can fix this one along the way as well?
I could give you the link to the screencast recording....if not clicking the go to my screencasts button in the screencast program gave a blank website in Chrome.
PG.Eng2
To make it a bit more interesting.
While typing above forum post Fusion was still non-responsive in the background.
Closed Fusion with task manager.
Restarted Fusion.
Get a message that there is a recovery file for the design file that was stuck before.
Opened that, and Fusion has created the operations from template in the recovery file.
Steven_Gao
Thanks for the additional information. Is it a little time-consuming operation? Do you have a chance to try it again and waiting for a little long time?
Steven
Steven Gao
Fusion & Inventor Quality Assurance
https://www.autodesk.com/campaigns/fusion-360/insider-program
PG.Eng2
Already tried on 2 different computers. Same result.
These few operations take a couple of seconds to generate when manually clicking the generate operations button for the complete setup when the template did work before.
