Fusion no longer starts up
ratch100
ratch100
Hi all,
So I started using fusion 360 non-commercial version about a week or two ago. started up, signed-in and worked no problems, all good.
Today I go to start up and carry on with a model and it is consistently crashing on start up. I've attached a pic of the screen I get and I've left it for 30mins or so to see if it just works itself through and I get nothing.
Since then I've uninstalled and reinstalled, reset, repaired it. Reinstalled with restarting pc, reinstalled with shutting the PC down to properly end all processes, nothing works.
I last used it either 2 or 3 days ago and it was fine, gone to start it today and I get this.
Is this new? any advice?
Many thanks in advance.
RajkumarIlanchelian
@ratch100 Looks like a graphics problem. Can you see if there is any graphics update pending and also any OS pending update?
Do you connect to multi monitors and if so can you disconnect and see if that helps?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
ratch100
Rajkumar,
Ah that's worked! So I normally have 5 monitors connected, I disconnected 4 and it's managed to boot to the main screen.
I'm not sure what to do now, I updated my NVIDIA drivers AFTER the problem so I don't think a graphics update caused the issue and all this worked with the 5 screens a couple days ago.
I've plugged the other 4 screens back in now and it's fixed, I guess if the issue pops up I'll just repeat this and make-do.
Thankyou kindly!
