Fusion locks up in the drawing space
TPrice_71
Message 1 of 16
TPrice_71
Hello everyone,
I am having trouble with Fusion freezing up when I am in drawing mode. No error messages of crash report windows pop up, it just freezes and I have to open the task manager to shut it down manually. It does it on every drawing when i am adjusting drawing views. When i am resizing a view, or turning on the xray view, it just locks up. While it happens on every drawing, it is somewhat random in the drawing. I never can pinpoint when it it will happen. I was hoping it would fix itself when the next update came out, but no such luck. It started after the previous update and I have been so busy,  i just had to live with it
Any help greatly appreciated!!
Replies (15)
Message 2 of 16
RajkumarIlanchelian
@TPrice_71 This appears to be a possible graphics problem?
1. Check to see if there are graphics card driver update available?
2. Also go into Fusion - help - Support and diagnostics - Graphics diagnostics and paste the information here?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 16
TPrice_71
[GPU Information]
GPU Device: NVIDIA RTX A2000 8GB Laptop GPU
GPU RAM: 8064 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 536.45
GPU Driver Date: 06/30/2023
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Message 4 of 16
TPrice_71
I updated my graphics driver and it still locks up every time.
Message 5 of 16
TPrice_71
I found this possible solution in a post with someone having a similar problem,
"I would also suggest that you set Fusion up in Windows, to run on “High Performance” graphics settings. These 2 changes should give you far better stability."
I went and set up Windows per the instruction and I am still getting lock ups. It seems to happen when I go to re-scale a drawing view.
Message 6 of 16
RajkumarIlanchelian
@TPrice_71 I am reaching out to our drawings team engineers. Will report back here shortly.
Autodesk Fusion
Join Fusion Insider
Message 7 of 16
reload11
I have nearly the same issue. While working in drawing space generating i.e. splines system crashes. Sometimes only Fusion but sometimes I got a blue screen.
System is a brandnew HP ZBook Power 15 G10
[GPU-Informationen]
GPU-Gerät: NVIDIA RTX 2000 Ada Generation Laptop GPU
GPU-RAM: 8064 MB
GPU-Treiber-API: DirectX 11.0
GPU-Treiberversion: 536.25
GPU-Treiberdatum: 06/12/2023
[Einstellungen für Grafikeffekte]
Anti-Aliasing: Ein
Umgebungsokklusion: Ein
Objektschatten: Ein
Schatten auf Ausgangsebene: Aus
Reflexion auf Ausgangsebene: Aus
Auswahl Anzeigestil: Einfach
Transparenzeffekt: Bessere Leistung
[Effekte beschränken, um die Leistung zu optimieren]
deaktiviert
Made a vid of the strange behaviour
[video]
. Working with the integrated Intel Iris grafic module does not cause any problems.
Message 8 of 16
reload11
Had nearly the same problem (see post before) but could reproduce the behaviour.
Changed today in the Nvidia Control Panel the application specific settings the energy saving setting for fusion to maxium and until now no crashes. Maybe this helps.
Message 9 of 16
LishuangLu
Thanks all for reporting and also sharing possible solutions!
@TPrice_71 Have you tried the workaround from @reload11 in above? Let us know if it can work for you. Thanks.
-Lisa
Message 10 of 16
liang_chen
This is a known issue and reported as internal ticket- FDWG-18009. We are still working on this random issue.
Thanks for your patience and feedback.
Fred Chen
SQA Engineer
Quality Assurance Team
Message 11 of 16
TPrice_71
I tried this workaround and the lockups still happen, but with less frequency!
Message 12 of 16
TPrice_71
Are there any updates on this issue? After the last update, I am back to drawing lock-ups on every drawing. It still happens when scaling the drawing on the sheet.
Message 13 of 16
liang_chen
Sorry for this issue, and we are still working on it.
Can you pls help to launch Process Explorer when work on Fusion? Please create mini dump files from both AcCoreConsole.exe and Fusion.exe when issue happens, and share the files with us. They will be helpful for us to check which processes have particular handles opened or DLLs loaded. You can also send them via mail. My mail address is 'Liang.chen@autodesk.com'
https://learn.microsoft.com/en-us/sysinternals/downloads/process-explorer
Fred Chen
SQA Engineer
Message 14 of 16
TPrice_71
Will do, thank you for the quick reply!
Message 15 of 16
liang_chen
We received some dump files from users, and added some improvement and fixing by the symptom found in Dump. Ideally, the fixing will reduce the frequency of this issue, and it is available in the new update of ProD versin (2.0.18477). Please update to the latest version, and let us know if this issue is still there.
Please share the dump files with us if you meet this issue again. Thanks for your support and patience.
Fred Chen
SQA Engineer
Message 16 of 16
reload11
As my workaround doesn't fix the video_tdr_failure completly and I got the same failure much worser with
MS Clipchamp I decided to contact HP service. After some reinstalls of the driver and shared minidump files
they thought that this is not a SW issue. They proposed to exchange the GPU which belongs to the MB.
A support technician came to me and did this as part of the onsite warranty :-).
Now (since 5 days) the failure doesn't appear anymore.
So keep in mind that there could be also a defective HW the reason for the failure - and it could be that the HW is defective form first second of use as mine showed it instantly after installation.
.... and MS Clipchamp might be a app to stimulate this kind of failure as 3Dmark doesn't do so.
