Fusion Local Rendering Problem
olaf.kelleFNCXT
olaf.kelleFNCXT
Hello, I'm coming from Autodesk Education Support and should post my support question here.
I have big problems with the local rendering.
The rendering process starts and then stops shortly before the end. The message "rendering could not be found" appears ...
In the RenderProcess.log file you can see that the memory buffer is filled, but then no image is saved, see attached RenderProcess.log:
image.Rendering progress: 100%Saved image to memory buffer, 1539198 bytes.Saved image to memory buffer, 77167 bytes.Saved image to memory buffer, 3939628 bytes.Filter feature buffers: 1280x1024Filter output buffer: 1280x1024
I have tried all the tips here in the forum several times - delete cache, delete user data, repair Fusion and reinstall Fusion. Nothing helps.
I am also attaching the diagnostic files.
Many thanks for your continued support!
olaf.kelleFNCXT
no support from Autodesk as announced or any idea whats wrong  ?
Yesterday I received a Fusion update, but this could not solve the problem either.
pepsimusic
I did also report this, but it's uncertain what is wrong. No available fix for this moment, I also tried all suggested fixes but still not working only in canvas render.
juhuttu
Community Visitor
Community Visitor
I have the same problem date 29.6.2025.
