Fusion keeps jumping back to the front of the other applications when trying to change to a different one
- Mute
- Permalink
- Report
Okay, I've reported this (as have others) in mutiple other threads, keeps being ignored, and I was asked to create a new thread. I know I'm not the only one seeing this. If you are on Mac and seeing related things, please keep them in other threads since it appears to blind Autodesk to the problem on Windows - thanks. If you are seeing this on Windows, please chime in!
This is on Windows 10, paid version of Fusion, everything is up to date. Working away in Fusion, with a windowed app (not fullscreen, not running from a browser like Edge or any others, the normal Fusion application). If I try and change to another application by clicking on its tab in the Windows taskbar at the bottom of the screen, the other application will come forward for a second then Fusion jumps back to the top of the stack again. Click on other appliction again, same thing happens.
Only way around it once it starts happening is to click on the descktop background, THEN click on the other application. Then it behaves. Till I go back to Fusion, and then try to bring another application forward again. At that point, same bug, Fusion pops itself back to the top.
This all seemed to start happening when Fusion tried to fix the opposite problem (which is still happening too, once in a while), where Fusion would send itself to the back behind another application when doing an operation that takes a few seconds.
It does not happen all the time, but seems to start doing it once I've been working for a while. REALLY annoying once it starts, breaks up the work flow severely.
