Fusion has turned into something really frustrating to use.
Post contains a very emotional rant about Fusion. Don't read if your feelings get easily hurt 🙂
This software has turned into a steaming pile of it. Select through is ALWAYS on, and even if you turn it of every single time, it still doesn't disable it completely and selections prefer anything but what I want to choose.
I mean, it is completely stupid of me to even expect to be able to select the nearest item when I want...
Projection on sketch decided to be unselect able later and didn't follow the original projected geometry anyway when I moved that. So totally useless. Can't change it as I can't select it and if I try to move the sketch to correct place, then this pile of s... decides to rotate the sketch rather than move... When will these software people learn how to do a user friendly software where things work and have a good, logical UI.
Wasted now 3 hours since I need to restart the whole thing as none of the saves will help as the issue happened on one of the very first sketches. I don't give a crap how much some other, WORKING, software is. I'm moving away from anything Autodesk ever does, if this is the way they prefer to programs their stuff. My time is too short and precious to waste it with this kind of things.
Rant end..
g-andresen
Why don't you create a screencast on (first) one of your points of criticism?
Then there would be a chance to determine where the cause of the problem lies.
günther
Could do. I'll try to get it done in the next couple of day.
