Fusion hangs on startup after installing add-ins
kswiorek
kswiorek
After installing any add-in, like Equation Driven Curve or FM Gears, Fusion hangs - the main window launches, but nothing happens after diplaying the logo. I have tried to do a clean reinstall from an article on this site, but it did not work. This is not the problem with those specific add-ins, because they work on a different computer perfectly. The only difference in logs I managed to find doesn't tell me anything - the longer one I attatched is after uninstalling the add-in and Fusion managed to launch.
It is really anoying to create gears on another, slower computer, wait for the file to be uploaded, close the program there, open it on this computer and load that project, so I'd be grateful if you managed to solve this problem.
kswiorek
Ok, managed to get it working by putting the installed add-in in a different folder than in AppData and then adding it through the add-in window. I have no idea why this fixes it, it may have something to do with the fact that I have the whole AppData folder on a different drive through a symlink, but I don't know how that would cause a problem.
