Fusion goes crazy after update
erwanlediraison
erwanlediraison
Hi everybody,
Since today's update, my fusion goes crazy.
If I right clic on sketch to export, nothing happen. Then I cannot select anything at all (all my selection filters are checked).
I can still click on command icons but I can't select anything after that and when I right click again on my sketch I get a giant rollout menu like that:
I tried to update my GPU driver, to reinstall Fusion and it doesn't solve the problem.
I tried on another computer and it works, so the problem seams to be with my computer but other software works well...
Someone knows about this issue?
Thanx
cncprogrammerer
seem to have  lot of the same issues as well
Phil.E
This is pretty strange.
  • Can you describe what the differences would be between your two machines? For instance, is one of them attached to a second monitor? Are they both windows OS? Any sort of physical or operating system differences would be good to know.
  • Please post the graphics diagnostic information (help > Support and Diagnostics > Graphics Diagnostic)
Phil Eichmiller
Software Engineer
Quality Assurance
canarvaezt
In my case, every generative study keeps failing, even cloned studies from a previously solved one šŸ˜ž
mbelusa.mail
I have also issue after last update. As you can see in attachment the scaling of the history toolbar is wrong. The icons are partially covered with slider
erwanlediraison
Someone told me to try to connect a second screen on the french forum.
It partially solve my problem because when I connect the second screen the window appear on my main screen (my laptop one) so I'm able to do what I whant but then, when I disconnect the screen the problem is back.
Just in case, I have a MSI ghost pro with GeForce GTX 970M.
erwanlediraison
Ok I solve the problem:
I ran Fusion with a second screen, I right clicked on the sketch to export, the window showed up in the main screen, then I closed the second screen via windows command, I closed Fusion, start it again and now everything is ok.
Hope this will help someone else!
