Fusion Freezs on Startup with white screen. Despite RESET, REPAIR and REINSTALL
Orientes
Orientes
I get a white screen on startup. Tried the Service Utility window, Reset Fusion, Repair Fusion and Uninstall/Reinstall. It hangs on the the same white screen after the splash screen. This morning, I was able to create a new project, when Fusion asked me to update. this started after the update. In the troubleshooting process I also updated Desktop Connector and Access. Same problem. Ran Network diagnostics, green board. And Health Services also gives a green board, except for Support
Orientes
And the solution is: disconnect all but one monitor from your PC (I have 3). How can a CAD design program in 2025 limit you to just 1 monitor???
RajkumarIlanchelian
@Orientes If you connect back the monitors they should work.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Orientes
Thanks. Yes, that's what I just did.
