Fusion freezing up with sketch's
Reading similar problem posts and seems this problem dates way back to 2012. Once you have a sketch much more complex then a few lines fusion has all sorts of trouble dealing with it.
Ive had the problem many times with different sketches or SVG's but the one today for example is a diamond crosshatch pattern which is made up of only about 64 line. If I try do anything with this sketch (delete a line, add a line, try to move it etc) fusion just freezes up... If I wait about 10 minutes sometimes it finally computes, somestimes not.
I need to project these lines to a curved surface then use trace tool path to engrave it which works really well once I finally get the sketch finished
Ive tried to attach the .dxf of the sketch but it wouldn't let me?
Just wondering if this is ever going to be fixed?
I have a pretty decent Alienware laptop with 16gb ram... Ive considered upgrading to a new one with better gfx card and 32gb ram but not sure if it will even help?
