Fusion freezing no matter what.
I have been trying for about 4 hours not to get fusion to create a pattern on path. I computed the same path with a cut and took about 2 minutes to compute total. After editing the drawing a bit, the original pattern turned out to not be needed however the program fills the hard drive with over 100 GB of files and refuses to do anything but continue filling the hard drive if I try to delete it from the timeline. I am also unable to create the new path for the stand off in the file as it just freezes and fills the drive just the same.
On the brighter side, I discovered that if you click off the Submit Report, you don't have to waste time trying to select the close button and it will just sit in the background till fusion 360 freezes the same way it has been for 6 months now.
