Since you are using a Fusion Personal License, you have up to 10 files that can be actively Editable at one time. You can click on the ones marked Editable and change them to Read Only if you need to free up some of the 10 files. Once you do this, select the Read Only and change it to Editable.
As far as the version remaining the same, you will have to attach the model for testing. If you do not know how to attach your model, open in Fusion 360, select the File menu, then Export and save to your hard drive as a F3D or F3Z file. Attach the file to a reply post using the Attachment section.
John Hackney, Retired
