Fusion Crashing error
Nicolas_G12
Nicolas_G12
Community Visitor
Community Visitor
Has anybody ever had experience with fusion crashing. If so, what is the solution. Like I will work on it regularly and it will crash, and when I will open it back up it will crash. And so basically impossible to work on.
Ihor_Radikhovskyi
Most likely this is not a “random crash”, but a broken feature in the timeline.
Typical pattern: works → crash → reopen → crash again = rebuild fails.
Try this:
  1. Open Version History and restore a version before the crash
  2. Start Fusion with Graphics Acceleration OFF (to rule out GPU)
  3. If it opens – suppress last features step by step
  4. If possible – Export as STEP and reimport (to clean corruption)
  5. Clear local cache:
    %LOCALAPPDATA%\Autodesk\Web Services
If older versions open fine → the issue is in the last operations.
Also worth checking what workspace / feature caused the first crash.
