Fusion crashes when generating drawings to new sheet
mda
mda
I've put together an assembly and need to generate a number of drawings for individual components in the assembly.  I want to put these drawings into one with each sheet representing a different part.  I've done this plenty of times in the past on various projects.  Having generated my first drawing on sheet one, I go into the assembly model and right click the next component I want a drawing for and click create drawing.  I then select the destination drawing as the currently opened drawing that contains my first sheet and choose new sheet and click ok.  At this point I am taken to the open drawing and instead of generating the new sheet and allowing me to place my base view, Fusion crashes.  I then open everything back up and go through the same process to create my drawing using the same component I previously tried and it works fine.  I save and then go to the next component I want a drawing of and get the same crash followed by success on the second attempt.  I have done this back and forth non-sense now for 6 components.  This needs sorting.  Sure, I can generate my drawings as individual instead of as sheets in the same drawing but that isn't the point.  I should be able to put them in one, on separate sheets.  I need an admin to look into this please.
kirti.gujar
Hello, I am sure it must be frustrating and I apologise for the inconvenience. However, I cannot reproduce it with any data on my machine, could you share your data and I could have a look at it.
Meanwhile, as a workaround you could try using a component template and select all the components while creating the drawing, this will create a drawing with a new sheet for every component.
I hope this helps.
