Fusion crashes at login
mark_gm_mail
Observer Observer
mark_gm_mail
Observer
Observer
Every time I try to open fusion it sticks out an error just at the moment I try to log in.
It all started, when I updated to the latest version of Fusion.
I’ve tried everything(
Reinstalling, uninstalling the app completely, updated mac os to the latest version, texted support and sent numerous reports.
I would so much appreciate your help, guys!
Thank you.
khalidlib
hello, i am not sure about OS but a wrong date and time settings could cause such a problem
RajkumarIlanchelian
@mark_gm_mail As @khalidlib mentioned make sure that the time is synced and the crash reports shows that it is likely related to network as well.
1. IF possible restart the machine and connect to a different network (say a mobile hotspot) and see if that launches.
2. What macOS are you on? In the privacy and security settings are there anything blocked by macOS?
3. IF you turn off internet to your machine and launch Fusion does it crash?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
mark_gm_mail
Observer
Observer
Hello @RajkumarIlanchelian and @khalidlib
Thank you for your time.
1) I’ve restarted the Mac of course, checked the date, its up to date) tried different networks Both at Home, in my Friends house and 2 different hotspots, doesn’t make a difference(
2) i’m on Mac OS 15.0.1 Sequoia.
I have no Idea what could have changed since the update of Fusion, but it used to work properly and I didn’t change anything in privacy and security settings.
3) when i turn off the internet, Fusion pops up an error message “no internet connection” at start up and crashes afterwards…
I would so much appreciate help, thank you!
FYi Crash report id number is: 784620012
RajkumarIlanchelian
@mark_gm_mail Can you go to the below page and there is an update to Autodesk Identify in that article at the bottom. Can you please:
1. Close Fusion
2. Go to Activity monitor
3. look for Autodesk Identity manager - end task
4. Restart machine
5. Now install the file from this article
6. Now launch Fusion
Autodesk Fusion
Join Fusion Insider
helloQ8DNN
Observer
Observer
I have read all the forums, articles with the same problem, checking the logs.
macOS: ~/Library/Application Support/Autodesk/Identity Services/Log/IdServices.log
I have found the solution.
The existence of a private key was repeatedly mentioned.
You have to open your "KeyChain" app search for "AdskIdentityManager" is a private key, delete and restart the Login process.
And vuala already starts with all the normality.
When solving this issue I found this article explaining the same thing from Autodesk itself: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Stuck-in-Sign-in-l...
Regards
Anton Sychev
