Fusion crashes at each start
KirillChepizhko
KirillChepizhko
Looked through existing threads and solutions - nothing helped. After clean install still crashes.
This is after most recent update.
RajkumarIlanchelian
@KirillChepizhko Does it give you a crash report to send in or is it a silent crash to desktop?
Are you Mac or windows?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
KirillChepizhko
windows 64
RajkumarIlanchelian
@KirillChepizhko
1. Suspecting it could be the same as this thread . Can you please try the solution in there?
2. If that did not work, can you please go to C:\users\USERID\AppData\Local\Autodesk\Autodesk Fusion 360\Unique ID folder\Delete NScloudBrowserCache*.dat. Did that solve the issue?
3. If neither of the above solved the issue can you collect log files as described in this article and attach it here? Will need the application logs and web service logs.
Autodesk Fusion
Join Fusion Insider
