fusion crash when trying to make sketch fillet
derProtoTyp
derProtoTyp
fusion360 crashes when trying to make sketch fillet between spline and arc if there are mirror constraints present.
see screencast
masa.minohara
Hi @derProtoTyp ,
Thank you for reporting the issue! I had a look at your crash report and it seems to be associated with a known issue. (FUS-37234) I'll pass your screencast on to the development team and let you know as soon as we have more information on this.
I apologize for the inconvenience.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
derProtoTyp
@masa.minohara  Thank you for looking into the issue! Is there a place where I can read more about the issue to find a way to work around it until it is fixed? Kind regards
Bernhard
masa.minohara
Hi @derProtoTyp ,
Thank you for your response! No, the issue is logged in the internal system and the customers don't have access to it.
I had a look at the ticket again and found that the development team has fixed the issue in the development version, and they are now preparing to release a fix.
I'll check with the team if there is a workaround that can be used in the current version and let you know as soon as I hear back.
Masanobu Minohara
derProtoTyp
Great! Thank you @masa.minohara !
