Fusion closes when I go to manufacturing environment
Message 1 of 9
Since the last windows update, every time I try to enter the manufacturing environment regardless of model fusion immediately closes without an error
I've tried reinstalling and the problem persisted
Replies (8)
Message 2 of 9
dsouzasujay
Hi @Anonymous ,
I assume you do get the error reports? If you do get them can you send them in? (Capturing a report ID the next time this happens would also help).
Also can you please extract and attach your diagnostic files? Those are found here:
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 3 of 9
attached are the most recent logs
Message 4 of 9
I've never seen an error report to give you a number for it just closes and when I restart its normal until I go to mfg
Message 5 of 9
RajkumarIlanchelian
@Anonymous @Can you please check if you have any pending Fusion update and if you are on 2.0.9719 version? We add a fix fir a very similar issue that you called out here.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 6 of 9
I'm getting an error that the update has failed I'm on version  2.0.9642
Message 7 of 9
dsouzasujay
Hi @Anonymous ,
Can you please try to install again with below mentioned ways.
"The update failed to complete..." when trying to update Fusion 360
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 8 of 9
RajkumarIlanchelian
@Anonymous Can you also please collect the diagnostic log files that could help us see what is happening? once you collect the log, you can simply reinstall over the build you have an I believe that should get you on the latest build).
Autodesk Fusion
Join Fusion Insider
Message 9 of 9
ok that worked i was able to update to the latest version and the issue resolved thank you
