Fusion 360 wont start
Hey guys,
I just changed to the personal use fusion 360 a couple of weeks ago and everything was working fine up until last week. Every time I try to launch fusion 360 it wont start. I even check the task manager and it shows that nothings running. I've reinstalled it multiple times now and keep running into the same problem.
jhackney1972
When you uninstall Fusion 360, have you used the proper method.  You need to use a Clean Uninstall to make sure your system is ready for the installation.  I especially recommend running the Cleaner Tool.  You will find all the information on this web page.
John Hackney, Retired
No, only for the first time I did a clean uninstall. One thing that I've noticed is that after the first time I did it, the clean uninstaller wouldn't show the file in the computer and would freeze so I would have to go into control panel and uninstall it from there.
jhackney1972
I am confused.  The instructions for the Clean Uninstall routine say to go the Control Panel first and under Programs and Applications, uninstall Fusion 360 before doing anything else.  From what you wrote, you are trying to do the Clean Uninstall steps BEFORE doing a normal uninstall using standard Windows processes.  If so, you have it backwards.
I just got to work as we speak. Dude thank you. Although the way you provided was different then the way that i saw way I saw online somewhere else. thanks man
