Fusion 360 Won't Load
james_carson
Message 1 of 53
james_carson
I updated Fusion 360, and now it either gets to about 45% and crashes or loads the Fusion support window.  I don't have the old install to try installing the older version.  I've tried uninstalling and reinstalling the latest version, and repairing it through the support window, but nothing works.
Replies (52)
Message 2 of 53
RajkumarIlanchelian
@james_carson We just released a new update 2702.1.58. Can you please install this version and let us know if you are still facing this problem?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 53
james_carson
When was it released? I updated this morning, and then the problems happened.
Message 4 of 53
RajkumarIlanchelian
Updated in the last 10 minutes.
Autodesk Fusion
Join Fusion Insider
Message 5 of 53
james_carson
Downloaded and installed again, it opens with the Fusion Service Utility again after installing.
Message 6 of 53
james_carson
Is there a specific location I can download it from? I downloaded the free use version again and am getting the same problems.
Message 7 of 53
james_carson
Any other ideas?
Message 8 of 53
dsouzasujay
Hi @james_carson ,
Please follow below article to install fusion
Before Install, Uninstall Older version
If problem persists, share the installation log files?
How to collect logs:
For installation or update errors.
  • Windows: C:\Users\(username)\Appdata\Local\Autodesk\autodesk.webdeploy.streamer.log
  • MacOS: Macintosh HD>Users>(username)>Library>Logs>autodesk.webdeploy.streamer.log
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 9 of 53
james_carson
That took me to the same download page I did this morning, so it's already been uninstalled and installed twice.  Attached is the log file.
Message 10 of 53
dsouzasujay
Hi @james_carson ,
Have you installed any Virtual machines on your machine or installing Fusion on a Virtual machine.
Also
  • Provide your OS version.
  • A screenshot of "45% and crashes or loads the Fusion support window"
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 11 of 53
RajkumarIlanchelian
@james_carson
Can you please try this?
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Autodesk Fusion
Join Fusion Insider
Message 12 of 53
james_carson
I did all this and still get the same results.
@dsouzasujay I'm running Windows 11 Pro version 25H2.  Attached are the screenshots you asked for.
Message 13 of 53
RajkumarIlanchelian
@james_carson IN the service utility can you click on gather system info and attach the Fusiondiagnostics.zip file that it generates?
Autodesk Fusion
Join Fusion Insider
Message 14 of 53
james_carson
Where does it generate that file to?
Message 15 of 53
james_carson
I can't find the Fusiondiagnostics.zip file
Message 16 of 53
RajkumarIlanchelian
@james_carson The file should be in this location - C:\Users\(username)\Appdata\Local\Autodesk\Autodesk Fusion 360\
Autodesk Fusion
Join Fusion Insider
Message 17 of 53
james_carson
it didn't create a zip file, but there was a folder there with that name, and I zipped that up.
Message 18 of 53
RajkumarIlanchelian
@james_carson @the logs shows an error 2 in the logs.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Missing-Files-Fusi...
here is an article. Can you check to see if any of that helps ?
Autodesk Fusion
Join Fusion Insider
Message 19 of 53
james_carson
It doesn't help. I've done the uninstall/reinstall thing several times now, and the registry entry is already set to 1
Message 20 of 53
RajkumarIlanchelian
@james_carson @Let me look at the logs some more. Can you try one quick test?
if you create a new admin user on that machine and install Fusion does that launch ?
Autodesk Fusion
Join Fusion Insider
