Fusion 360 Versioning Bug?
m.vangrouw
m.vangrouw
Hi All,
I recently updated to Fusion 2.0.13615 on Windows 10 Pro, however, on closing and reopening Fusion, I revert to version 2.0.13168, which means I get error messages on my more recent files. If I reset fusion using the service utility, the about page shows v2.0.13615 until I restart fusion , at which point it reverts to 2.0.13168 again. I have included screenshots of the relevant pages and messages. Any ideas what is going on and how to fix it permanently? I can work around if for now, but its inconvenient having to reset fusion every time I start the software.
Thanks for the help!
Error Message:
About Window:
About page after resetting using Service utility:
About page after closing and reopening fusion:
Phil.E
Have you ever installed Fusion Insider builds?
Can you please gather diagnostic logs from this machine and email to me? phil dot eichmiller @ autodesk dot com.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
m.vangrouw
Hi Phil,
I just sent the logs. I have not installed any insider builds that I can recall.
Matthew
dooyoul_chung
@m.vangrouw
Thank you for sharing log file. Could you please restart PC and check you still have the same issue? Some reason, there is unexpected additional process is running and blocking cleanup after update.
Dooyoul.
m.vangrouw
Hi Dooyoul,
I restarted my PC, opened Fusion, and was still on v2.0.13168, but when I closed and reopened Fusion, again, the update was installed properly. I no longer have the issue. That was a good suggestion! Thanks!
Matthew
