Fusion 360: Unable to open any projects
donavin.m.peck
donavin.m.peck
I'm still fairly new to Fusion 360 and 3D rendering in general, but I recently ran into a BIG problem that I never encountered before.
I recently updated Fusion 360 to the latest version on my Windows computer. Upon updating I am now unable to open ANY of my projects. When I try to open 2 of my projects, Fusion tells me it can't download the file and any other project just makes the program freeze. I have tried opening projects from the "Open File" command, the Projects Tab (I believe that's what it's called, it's the 9 square command next to "File") and from the Autodesk website but with no luck.
I have spent many hours (sometimes days) on some of my projects and I am kind of freaking out that I may have lost all of my hard work. Any help would be greatly appreciated.
jhackney1972
Have your tried to view / download your files from the A360 database?  If you can log in here you should be able to log in and open files with Fusion 360 using the same credentials.
John Hackney, Retired
tyleradams8
I am also having problems downloading certain past projects.. There seems to be no rhyme or reason as to which designs but I have attached some of the error messages..
Also have tried to promote previous versions of the design with no luck...
