Fusion 360 Slow Performance When Computing Faces
ThePieMonster
ThePieMonster
As you can see via the attached video, the performance is quite slow when attempting to perform "remove faces" operation.
Any way to improve performance of this simple part?
TrippyLighting
Is the geometry imported, or was it created natively in Fusion?
If it was imported, could you share the original file you imported?
ThePieMonster
It was a imported design. When re-creating the part in Fusion 360 it performed better.
I since deleted the original which was a 8x12cm but I attached a smaller version that is basically the same thing.
TrippyLighting
I don't experience any slowness with the model you attached. Removing faces (auto repair) functions instantly.
ThePieMonster
Its a different model in this case, the other one was geometrically larger. If I encounter it again I will post back here.
