fusion 360 showing already installed but its not in my windows pc
2021me6
Observer Observer
2021me6
Observer
Observer
fusion 360 dialog box showing a latest version is alredy installed but there nothing to be found
And showing winerror2 a specified file missing
RajkumarIlanchelian
@2021me6 Can you please try this?
1. Go to add remove/remove program
2. Do you see Fusion 360 on that list?
3. If you DO then select it and - MODIFY
4. This will launch the Fusion service utility
5. Run the "Repair Fusion"
This should take care of the problem
Now if in Step 2, you do not see Fusion 360 on the list, can you right click on the short cut that you are launching Fusion 360 and see where the Fusion 360.exe is running from?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
2021me6
Observer
Observer
Thank you
That worked!
