Fusion 360 Sheet Metal Flange "Ok" button not available
alex_rosePX4V2
alex_rosePX4V2
I just upgraded to 15299.  When creating a new sheet metal flange, SOMETIMES, the "Ok" button remains grayed out and unavailable.  However, if I click "Save", it will go ahead and create the flange, and close the flange dialog box.  I can re-open and edit as necessary.  Took me a while to figure this out.
sutherland-
Hi @alex_rosePX4V2
Is your OS and computer drivers up to date as well?
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
alex_rosePX4V2
I just tried to update my graphics drivers, and the version being reported by the Device manager is a later release than what I can download from the mfg website- display_drivers.png
It's also worth noting that I'm on Windows 11, and the display drivers don't show any download options past Windows 10.
Having said that, my sheet metal flange operations worked fine until I upgraded Fusion.  Surely I'm not the only one experiencing this.  Given that it generally runs fine and all other features work as expected, I'm satisfied that this is not a driver issue.
sutherland-
Hmm, it is weird, I cannot reproduce the issue you are having. Have you tried to do a full manual uninstall of F360?
Best regards,
Level  sutherland-
Member
maxSE6ML
Im having the same issue. very strange bug
TheCADWhisperer
@maxSE6ML
Can you File>Export your *.f3d file that exhibits this behavior to your local drive and then Attach it here to a Reply?
I suspect there is an easy solution.
