Fusion 360 saying not responding and then crashes
Every time I open Fusion 360, within 10 - 20 seconds the error report dialog comes up, but it's strange that although the error report dialog is displayed, I am still able to use Fusion 360, but only for 5 - 10 minutes and then Fusion 360 says not responding for 2 - 3 minutes and then seems to work OK and then Fusion 360 says not responding for another 2 - 3 minutes, it goes on for about quarter of an hour like this and then the Fusion 360 window crashes. The error report dialog stays up, from when it came up 10 - 20 seconds after Fusion 360 had finished opening.
I have tried quite a few different files and it happens on all of them, so it's not just one corrupted file that's causing the issue.
I've updated the graphic drivers and done a clean uninstall of Fusion 360 and it still happens.
The number of the error report that I did from the error report dialog is: 310663469
The graphics diagnostic:
[GPU Information]
GPU Device: NVIDIA Quadro T1000
GPU RAM: 3968 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 471.68
GPU Driver Date: 08/06/2021
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
