Fusion 360 Render outputs empty image file.
pvp1F8KUU
pvp1F8KUU
Hi I am currently using the fusion 360 render engine to show some concept images and the output image file is blank. When "Transparent Background" is selected. I have a model with default lighting and fusion materials used. In this case stainless steel and kapton.
When I render with both the cloud or a local render I get an visible output in the Render Gallery.
However when I export as a .tiff or a .png file with a transparent background the image is completely blank
If I turn off transparent background I get the image with a grey background which isn't an ideal solution for my use case.
What I've tried:
- Restarting Fusion 360
- Re-rendering the file
- Changing the lighting conditions
-Changing local vs cloud render
- Rendering other files (They work perfectly fine - so I don't know what's wrong with this one)
TrippyLighting
Can you share the model?
pvp1F8KUU
Yes of course - see attached
jhackney1972
Seems to work fine on my end.  PNG is attached.
John Hackney, Retired
pvp1F8KUU
Hmm strange it still doesn't work on my end, well thank you either way!
jackjanyjanu7
Community Visitor
Community Visitor
Hi! It sounds like the "Transparent Background" option in Fusion 360 might be causing the render issue. Try turning off transparency to see if the model appears correctly. You could also check the gallery settings to ensure everything is being captured properly.
