fusion 360 "edit in browser" not working
Message 1 of 9
Using Chrome the "edit in browser" button opens up another tab that eventually times out and says "an error occurred while loading that design:[Object object]."
Replies (8)
Message 2 of 9
In Firefox it does the same thing except that a warning pops up that I'm using an unsupported browser.
Message 3 of 9
paul.clauss
Hi @Anonymous
Thanks for posting! I noticed this same behavior on my end with every file I tested with and most of the support team experienced the same behavior. From my testing so far, this occurs on both my Mac and Windows machines in every web browser I've tested with.
I've logged internal ticket FUS-57591 with the development team to investigate further. As the browser version of Fusion 360 is a tool that is still only accessible as a preview, I cannot provide any guarantees on if or when this issue will be resolved.
Paul Clauss
Product Support Specialist
Message 4 of 9
pierre-yves.monarque
Hi Robert
It should be fixed now.
Sorry  for this issue.
Please let us know if it is still not working.
Pierre-Yves Monarque
Autodesk Fusion 360 Team
Message 5 of 9
shollenbeck5MNK2
I continue to get the same error trying a number of different ways to access the fusion 360 browser version
Message 6 of 9
henderh
Thank you for reporting it @shollenbeck5MNK2. We're working towards a resolution (ID-27255).
We apologize for the inconvenience this is causing.
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
Message 7 of 9
shollenbeck5MNK2
Thank you. It seems to be working now.
Message 8 of 9
henderh
Perfect! We appreciate the follow-up @shollenbeck5MNK2.
Hugh Henderson
Message 9 of 9
I'm still getting this error unfortunately.
It started with an error (on chrome) that the file was saved in a newer version of the software, which now changed to the error stated above.
On firefox it gives the file version error just like chrome did first.
I'm running on linux, so it would be nice to have web fusion working.
Anything I can do to fix this?
