Fusion 360 queue keeps getting stuck no matter how many times i reinstall it
faguera01
faguera01
I've had a lot of problems in the last month where fusion 360's upload and save queue gets stuck. i cant upload anything, nor save my design. I found in the forums that the solution was to get the design manually in the AppData folder, do a clean reinstall and then upload the file as a new design. Considering i live in a rural area with a slow internet connection, this usually meant between 2 and 3 hours of work lost. However, it has gotten worse. during the last two days i've reinstalled it 5 or 6 times and it wont do anything. I cant save anything. I had to use my laptop just to upload my design. And that went flawless. I cant understand what is wrong with my main machine. Please help
rhudaynath
Hi @faguera01 ,
Sorry that you are facing this problem.
Please check article https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fil...
Can you please share UploadQueuedFileList.xml  from the path mentioned in above article?
Rhudaynath
Software Engineer
