Fusion 360 network diagnostic shows having connectivity issues
jgre2802
Message 1 of 24
jgre2802
So I recently have been using fusion 360 but then one day when I tried to open it, it asked me to login so I clicked the sign in button and it said that it would sign me in but nothing happened I looked up the issue and they said to change your default browser so I changed that (didn't help) then I tried uninstalling and reinstalling also didn't work then final I took a network diagnostic test and I think that's the problem I just don't know how to fix it. I inserted two pictures below of the error i'm getting.
Replies (23)
Message 21 of 24
jgre2802
Tried that but dosen't seem to work also thanks for helping try to work this out for so long.
Message 22 of 24
RajkumarIlanchelian
@jgre2802 Ok. This is certainly tied to the browser access. So when you made Firefox your default browser and then followed the article to search for the applications, you mentioned that Autodesk Identity was not part of it.
So there is one another one that we can try but before that when you go into task manager do you see Autodesk Identity running?
if you dont then lets do this:
1. Make sure Fusion is not running in task manager
2. Follow this article and it ill tell you how to download and install Autodesk Identity manager for windows
3. Once this is installed try to launch Fusion
4. If it does not work:
5. Now make Firefox the default and set the application (hopefully now you can see Identity manager to make it default per the other article I attached before).
If all this works then we know we have to do the same for Chrome and go back to making chrome your default browser.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 23 of 24
jgre2802
Ok so, I tried doing your method but it didn't work and I heard the people that reset there computer could help fusion work agian so I reset my computer and selected the option that said keep all the files but apps will be deleted and this worked! I also wanted to thank you for all of your help in trying to assist me in figuring this situation out so THANK YOU VERY MUCH. Your time is much appreciated.
Message 24 of 24
RajkumarIlanchelian
@jgre2802 @Glad to know that you are back to using Fusion.
Autodesk Fusion
Join Fusion Insider
