Fusion 360 (Mac/2.0.14569) becomes unresponsive when attempting to apply a fillet to this extrude/loft intersection
tomjulier
tomjulier
Test file attached.
TrippyLighting
Such slow response times usually mean Fusion 360 attempts to provide a solution, but encounters difficulties due to inadequate geometry.
In this case the cylinder / circle has the same diameter as the witdh of the box. A rolling ball fillet would not have a crease to roll in as it approached the center of the fillet I have highlighted with the arrow. In that area the crease needed to create a fillet will be zero, so the tool fails ... after trying to far too long to find a solution .
A proper fillet for such geometry is much more work in this case than clicking on an edge and filleting.
Model is attached
Also, please note that for lofts that have tangent inputs the keep tangent edges should be selected:
Steven_Gao
Thanks @TrippyLighting for analyzing the problem and sharing the good practice. I also logged an internal defect to ask development team to take a look.
Steven
LishuangLu
@TrippyLighting , the slowness has been already fixed, please have a try and let us know if you still notice the slowness in your side. Thanks!
TrippyLighting
It is indeed much faster !
I have yet to try it on other models.
LishuangLu
Thanks for your quick try, Peter! Let us know if you still see the slowness with other models.
