Fusion 360 Leaning Module Videos not playing
monteirom6FKBQ
Observer Observer
monteirom6FKBQ
Observer
Observer
I’m not sure if this is the right board, but I wanted to report an issue with the student learning modules. It seems that the sample examples—which typically play videos showing drawings and step-by-step instructions—are not playing. I also noticed that these modules are set to read-only, which I suspect is intentional, as students likely aren’t meant to edit them. If anyone is able to assist, I’d appreciate it. Thank you.
@monteirom6FKBQ Topic title has been edited to improve findability by CGBenner. Original: Fusion 360
jhackney1972
Please post a Hyperlink of one of these files which will not play.
John Hackney, Retired
CGBenner
@monteirom6FKBQ
Hello, do you still need help with this question?
Chris Benner
monteirom6FKBQ
Observer
Observer
No, there is no hyperlink. In the Fusion software there are videos in the embedded, that when you try to play the they do not work. I will try submitting a screenshot.
monteirom6FKBQ
Observer
Observer
jhackney1972
The "arrow" your screen capture is point to is used to automatically step through the timeline of an assembly or model.  This is not to control a training video that may be posted by Autodesk.  You can open any model under the Basic Training project and set through it using this icon.
monteirom6FKBQ
Observer
Observer
Thank you.
