Fusion 360 Launching Issues
mcallistermark2023
Observer Observer
mcallistermark2023
Observer
Observer
When I try to load Fusion I get the following error message:
Fusion 360 -- DB error: // no more rows available
Please report this error and editing steps prior to this error to Autodesk.
Unexpected Condition details:
File: R:/Electron/EAGLE/src/LibrariesIndex/DB/SQLite/SQLiteQuery.cpp, Line 60
Please help.
RajkumarIlanchelian
@mcallistermark2023 This is the same issue as we are tracking in this thread - https://forums.autodesk.com/t5/fusion-360-support/cannot-access-fusion-360/td-p/11068312
Please follow that thread for updates. We are trying to understand the issue at this time.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
@mcallistermark2023 Here is a workaround we have for now while we take a look at a fix for this issue. Can you please let us know if this worked?
Please close Fusion (maybe need to force quit and make sure there is no process of Fusion 360 in Task Manager) > go to below folder to delete the db file on your Windows OS > Relaunch Fusion again with only one instance.
C:\Users\{YourUername}\AppData\Local\Autodesk\Autodesk Fusion 360\Electron\{YourUId}\lbr\libraries.db
Autodesk Fusion
Join Fusion Insider
mcallistermark2023
Observer
Observer
I tried that and it still doesn't load. I've contacted my school district
IT about it. Something in the R drive also.
Hi @mcallistermark2023 ,
Sorry for any inconvenience.
Today we have put a fix in latest Fusion Production build 2.0.12670 pushed today, could you please delete the below two db related files (if there are) once again by following the steps mentioned in AKN file here and then relaunch Fusion > Live update to new version?
Hope it works for you.
Please feel free to let us know if you have still have the issue.
Thank you.
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
