Fusion 360 iOS App - Model Viewer Bug
Joshua.mursic
Joshua.mursic
There is a bug in the Fusion 360 Mobile app where the model viewer screen will be white while the user is not touching the screen. Not sure where we should report bugs, so hopefully this finds its way to the correct place.
jhackney1972
I had the same issue on my iPad.  I solved it by closing all applications and then holding down the Power Button until the Power Off slider appears.  Slide it to turn the device off completely.  Count to twenty, let some time past, then hold the Power Button until it restarts.  After this, the Fusion 360 app worked well.  I hope it works for you.
John Hackney, Retired
Joshua.mursic
This worked, thank you @jhackney1972
