Fusion 360 installing Error at 99%
for_reg_arn
Observer Observer
for_reg_arn
Observer
Observer
This is the log :
2024-04-12 13:11:52,103 - MainProcess(15568) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\user\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-04-12 13:11:52,103 - MainProcess(15568) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-04-12 13:11:52,103 - MainProcess(15568) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-12 13:11:52,103 - MainProcess(15568) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000220A8E51508> #
2024-04-12 13:11:52,103 - MainProcess(15568) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-12 13:11:52,103 - MainProcess(15568) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\user\AppData\Local\Temp\7zSEEF.tmp\resources\buildinfo.json
2024-04-12 13:11:52,103 - MainProcess(15568) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-04-12 13:11:52,103 - MainProcess(15568) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20220121171800
2024-04-12 13:11:52,103 - MainProcess(15568) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: bg_BG
2024-04-12 13:11:52,119 - MainProcess(15568) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\user\AppData\Local\Temp\7zSEEF.tmp\resources
2024-04-12 13:11:52,119 - MainProcess(15568) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\user\AppData\Local\Temp\7zSEEF.tmp\certs.pem
2024-04-12 13:11:52,119 - MainProcess(15568) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-04-12 13:11:52,119 - MainProcess(15568) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-04-12 13:11:52,119 - MainProcess(15568) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-04-12 13:11:52,119 - MainProcess(15568) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleancacheall=False, cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, globalinstall=False, headless=False, infofile=None, install_origin='Streamer', language='en', launch_args='', logfile=None, loglevel=20, no_auto_launch=False, no_cleanup=False, no_uninstall_registry=False, operation=<function multiple_operate at 0x00000220A9498048>, pipes=None, procfac=<function deploy_process at 0x00000220A93F53A8>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5, update_connection=None)
2024-04-12 13:11:52,119 - MainProcess(15568) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-04-12 13:11:52,119 - MainProcess(15568) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-04-12 13:11:52,119 - MainProcess(15568) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-04-12 13:11:52,119 - MainProcess(15568) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-04-12 13:11:52,306 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-04-12 13:11:52,306 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\user\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-04-12 13:11:52,306 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-04-12 13:11:52,306 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-04-12 13:11:52,306 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-12 13:11:52,306 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-12 13:11:52,353 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-04-12 13:11:52,353 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-12 13:11:52,353 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-12 13:11:52,353 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-12 13:11:52,353 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-04-12 13:11:52,353 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-04-12 13:11:52,416 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.87.176.182
2024-04-12 13:11:52,463 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-12 13:11:52,463 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjE3Ni4xODI=
2024-04-12 13:11:52,463 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTY5LjI1NC4wLjM=
2024-04-12 13:11:52,463 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-12 13:11:52,463 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-04-12 13:11:52,666 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-12 13:11:52,666 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-12 13:11:52,681 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-12 13:11:52,681 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-12 13:11:52,681 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-12 13:11:52,869 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 405cd76a-e18e-4e16-916d-f1d6fd5f137a
2024-04-12 13:11:52,900 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.18950 for app 73e72ada57b7480280f7a6f4a289729f
2024-04-12 13:11:52,900 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 21c715f12ee74317099a63da34b2ae75b58b7e5e detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b15b1b7805b8ba2d62d0eb75be63034b3319f9c6 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 2f60c789cb64b897082c14f8e7b32e22175531fe detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 2dff5a9885bd4d14707f07cc0c387384b410d8f4 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk ce5cbcf1b12323e8582d13482460252c99220b2f detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 2f663205f24eb5000c43172117b1d5d8ad8f021d detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 78603b8f518e64854f303f3622fdfe14658bafb4 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 55ea6a4dab227c03040c81a5b16c50784554dc07 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 785564d37ba80c24f842d8399576a1f51d99efb9 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 9475dfd2d73cb91f4df11ae0ec983bbe5f6b71e8 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 936c25d1c6be9e1e23d543b7aabf67d72891b802 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk fc69e4a2fa129a90b7f3fff7610bf3e1bf85eff3 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk d96074db931873b34f03c8cad66460ad920c147e detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk d2ae54241790248b9509cc2d93acbfd8da3a0fb0 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c847c35fa75f96b1dcd8003d6a8eadca16a6ad70 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 0af994da0c61208dd60fda5535a95e92aa2a7f52 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 67380f89d2d836c40053f0a5014c786a0b768d52 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 4e5457a31e2d5210ab1fb050938f79cbc7c7495b detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 8df49e583a856c4cb5e10d6932b4fe73c57be8a5 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 21b014fd1fbfb89e20e07e035120eabc9cc2a3fa detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk bc810c8ec2aa1b2f54a4b474ce4c23056b236375 detected on system skipping install.
2024-04-12 13:11:52,931 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b30915bf998f863569ebfca2d64f703f94440608 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 721377845673b0a5e03f8088c0c7005c3ea3565a detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 2764d962cc7daa21db6f36e9552ce602fe1a3c07 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk a319f266123ddcbde382512eba326bfc1fb942d2 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 079b11b2f834f23fb05ea23e43b36255876d1a29 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c4fec43a67eae44bff83ec4685a69a92c5b15fa6 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 00d792414ac403099c716c22e25bb81e37b13695 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 2a1de4e0a620854e43b78d70bec6de68fbbbf2d7 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 47f1bfd905f6efce3c53766e0e83e1547e9a0b27 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c621370e29581a87a66a0b400b423ef280290544 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 00fd1302af61935438c84b7237daa1ff0d0055dc detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 17da203864f95020aec7cd204e218dde7498d953 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6ed3a7465979bbbf48d46b7a297c018ff4f3df1b detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk dd6bf473d4f91f0829e7a4e7cf4a05c6d533925e detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 73c592c74ab19b6ca3e301a07569f7497b02d380 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1fb37ebde0577137dae7f50ea3e3d399a1cea477 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cf4b296685f85e523e35679dd03983fad34df9de detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 9790b96b35a797f8cbca9188d08cb35849835d11 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 0832d8d18156ee1046440fe8748f2a57911d785a detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 629ae19d1bf99325db0632226693cd34c109733b detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 17a8ce1bede26a8fe0e1efa306867edf63458a9c detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cd208a012d05fc583a0a456a51203feead7c2509 detected on system skipping install.
2024-04-12 13:11:52,947 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 93307e3d214287b72634a8907866f1ce7852a784 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cd398d360d746179da04a19fe608256034f75a64 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 4de12dede526ac2b069a341d5da656e9cb790f63 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 91b701817de89df827d150a5f19f0151c3a0f349 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 58f6d754f624b88802dc181c7f035cf4538747ed detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk de41f3aed1fda27c5cc5927d8e0bae724448cc54 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk abba54b0165644ed49b931bd08b9ccbb80cfd9ac detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 188fbfc969c0ce850598363d86904da9a763af79 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk ca62249827fdfde936f3426ba0d37a3c5de08a18 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b16536d889d0708f2d09a56698ace6a9c71e94a9 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 7e3f9c193b925b2cf7e905522997fdde457f2dfb detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 424f9b04f51c004d57e5c0681af0d039fdf73900 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f4744c3170eac235ea2b8cf9e76a6be45744d4c7 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5a3ac34067346d15ef82d71a764fd48047f3f21c detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 0b7b28a37af3c823ebc323d9776e65fb59cf7a92 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f260131e3b10693d42557009eda8c26673641f7a detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk a76604f37f5c4c4ef4d2b31fd7f99a780abc9519 detected on system skipping install.
2024-04-12 13:11:52,963 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk ed71274a523df81ba196cf22b7dc36be5e7efa0a detected on system skipping install.
2024-04-12 13:11:52,978 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e8fb7bcbd97a48fe7f593ae5b0ab65b3f09fce39 detected on system skipping install.
2024-04-12 13:11:52,978 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-04-12 13:11:52,978 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-04-12 13:11:52,978 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2024-04-12 13:11:52,978 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 99fa7380261aad1710f7cd69c74ba4edd588af50
2024-04-12 13:11:52,978 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/99fa7380261aad1710f7cd69c74ba4edd588af50.js...
2024-04-12 13:11:52,994 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-12 13:11:52,994 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-12 13:11:52,994 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-12 13:11:53,166 - MainProcess(15568) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/512abb64f6be9b1392cfb4e167643e62d27087b8.ta... for package 99fa7380261aad1710f7cd69c74ba4edd588af50
2024-04-12 13:11:53,166 - MainProcess(15568) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2912c16c8fe768ee60d92170e519b110d82f64fb.ta... for package 99fa7380261aad1710f7cd69c74ba4edd588af50
2024-04-12 13:11:53,197 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Start executing tasks thread
2024-04-12 13:11:53,197 - MainProcess(15568) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-12 13:11:53,228 - MainProcess(15568) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-12 13:11:53,228 - MainProcess(15568) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-12 13:11:53,228 - MainProcess(15568) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-12 13:11:53,228 - MainProcess(15568) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-12 13:11:53,228 - MainProcess(15568) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-12 13:11:53,400 - MainProcess(15568) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32
2024-04-12 13:11:53,400 - MainProcess(15568) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32
2024-04-12 13:11:54,228 - MainProcess(15568) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: received bytes: 1844704, total bytes: 1844704
2024-04-12 13:11:54,228 - MainProcess(15568) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-04-12 13:11:54,572 - MainProcess(15568) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: received bytes: 4498824, total bytes: 4498824
2024-04-12 13:11:54,572 - MainProcess(15568) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-04-12 13:11:54,572 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 99fa7380261aad1710f7cd69c74ba4edd588af50
2024-04-12 13:11:54,572 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action e10f096356f7470ea58e13af02d1ba7c(UPDATE_PINNABLE_LAUNCHER)
2024-04-12 13:11:54,572 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action e11b50c4e45d49c68aa944c2e476a76f(Unknown) was not in registry
2024-04-12 13:11:54,572 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-04-12 13:11:54,572 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\streamingsession.json
2024-04-12 13:11:54,588 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 7df3ec3a7e8d40ada66494b9dc32dc4e(ACTIVATE_CONFIG)
2024-04-12 13:11:54,603 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\Applications\Fusion\Fusion360App\ApplicationOptions.production.xml as \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\Fusion 360.server.config
2024-04-12 13:11:54,603 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-12 13:11:54,650 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\Applications\Fusion\Fusion360App\ApplicationOptions.us-production.xml as \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\Fusion 360.us-server.config
2024-04-12 13:11:54,650 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-12 13:11:54,666 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\Applications\Fusion\Fusion360App\ApplicationOptions.emea-production.xml as \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\Fusion 360.emea-server.config
2024-04-12 13:11:54,666 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-12 13:11:54,697 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\Applications\Fusion\Fusion360App\AdpSDKGlobal.production.config as \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\AdpSDKGlobal.config
2024-04-12 13:11:54,697 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-12 13:11:54,744 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\Applications\Fusion\Fusion360App\adpdesktopsdk.production.env as \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\80334f1f1d9684bdf5e16fc8205e53367e0cee32\adpdesktopsdk.env
2024-04-12 13:11:54,744 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-12 13:11:54,744 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 8df63efc00a94e9aa262d921a044c83a(PROCESS_TEMPLATE)
2024-04-12 13:11:54,744 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 9a6f9239365141149849b3081dc3fd7c(WRITE_STREAMER_OPTIONS)
2024-04-12 13:11:54,744 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '0' to option 'GlobalInstall'
2024-04-12 13:11:54,744 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Remove option 'DevBuild'
2024-04-12 13:11:54,775 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-12 13:11:54,775 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-12 13:11:54,775 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-12 13:11:54,947 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: The ETag of url https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f... is ad2d8f54b83f32f71e1a2e7bd5fc9913:1712761320.224332
2024-04-12 13:11:54,947 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...' to option 'StreamerRootUrl'
2024-04-12 13:11:54,947 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'ad2d8f54b83f32f71e1a2e7bd5fc9913:1712761320.224332' to option 'ETag'
2024-04-12 13:11:54,947 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'production' to option 'InstallStream'
2024-04-12 13:11:54,947 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1341bb4b8566410e9c7c8aef52bcb222(FILE_ASSOCIATIONS)
2024-04-12 13:11:54,994 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-04-12 13:11:54,994 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 4afd20f9b05b4349869fb10841d11444(DELIVER_ICON)
2024-04-12 13:11:54,994 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Deliver the icon of Fusion360.exe to the same folder as the Pinnable launcher.
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico stat result: os.stat_result(st_mode=33206, st_ino=1125899907752446, st_dev=351482882, st_nlink=1, st_uid=0, st_gid=0, st_size=177333, st_atime=1712916673, st_mtime=1712715167, st_ctime=1712911975)
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico st_file_attributes: 32
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico stat result: os.stat_result(st_mode=33206, st_ino=2814749767975900, st_dev=351482882, st_nlink=1, st_uid=0, st_gid=0, st_size=40507, st_atime=1712916670, st_mtime=1712715229, st_ctime=1712911975)
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico st_file_attributes: 32
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico stat result: os.stat_result(st_mode=33206, st_ino=1407374884463103, st_dev=351482882, st_nlink=1, st_uid=0, st_gid=0, st_size=39964, st_atime=1712916670, st_mtime=1712715229, st_ctime=1712911975)
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico st_file_attributes: 32
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico stat result: os.stat_result(st_mode=33206, st_ino=2533274791265714, st_dev=351482882, st_nlink=1, st_uid=0, st_gid=0, st_size=39624, st_atime=1712916670, st_mtime=1712715229, st_ctime=1712911975)
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico st_file_attributes: 32
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico stat result: os.stat_result(st_mode=33206, st_ino=2814749768007008, st_dev=351482882, st_nlink=1, st_uid=0, st_gid=0, st_size=39217, st_atime=1712916670, st_mtime=1712715229, st_ctime=1712911975)
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico st_file_attributes: 32
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico stat result: os.stat_result(st_mode=33206, st_ino=2814749768015265, st_dev=351482882, st_nlink=1, st_uid=0, st_gid=0, st_size=38223, st_atime=1712916670, st_mtime=1712715229, st_ctime=1712911975)
2024-04-12 13:11:55,009 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico st_file_attributes: 32
2024-04-12 13:11:55,025 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action abd8ee230bcc49f9a56035b8eefedeed(REGISTER_UNINSTALL)
2024-04-12 13:11:55,025 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\user\AppData\Local\Autodesk\webdeploy\meta\streamer\20220121171800" is found
2024-04-12 13:11:55,025 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\user\AppData\Local\Autodesk\webdeploy\meta\streamer\20220121171800\streamer.exe"
2024-04-12 13:11:55,025 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - WARNING :: Already installed the latest streamer, do not need to update the streamer
2024-04-12 13:11:55,025 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Create shortcut file: C:\Users\user\AppData\Local\Autodesk\webdeploy\meta\streamer\streamer.bat
2024-04-12 13:11:55,025 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Creating uninstall registry key "Software\Microsoft\Windows\CurrentVersion\Uninstall\73e72ada57b7480280f7a6f4a289729f"
2024-04-12 13:11:55,072 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action 5ca4357a038540d58fb2092e8a9329a9(Unknown) was not in registry
2024-04-12 13:11:55,072 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-04-12 13:11:55,088 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-04-12 13:11:55,088 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 0b9a4c1251914f7facc25616ea0f9de3(CREATE_LAUNCH_ITEMS)
2024-04-12 13:11:55,103 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-04-12 13:11:55,103 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\user\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is launchable. Creating a shortcut
2024-04-12 13:11:55,150 - MainProcess(15568) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Exception processing tasks for 99fa7380261aad1710f7cd69c74ba4edd588af50:
2024-04-12 13:11:55,181 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-12 13:11:55,181 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjE3Ni4xODI=
2024-04-12 13:11:55,181 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTY5LjI1NC4wLjM=
2024-04-12 13:11:55,291 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgZG5zMS51bmljc2JnLm5ldA0sIEFkZHJlc3M6ICAxODUuMjAuODguMQ0=
2024-04-12 13:11:55,291 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-12 13:11:55,291 - MainProcess(15568) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 1119, in execute
File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 1066, in execute_without_errorhandling
File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 895, in _config_app
File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 1824, in _do_installation
File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 1589, in wait_threads
File "E:\Jenkins\3P\PYTHON\3.7.6\WIN64_1\lib\concurrent\futures\thread.py", line 57, in run
File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 1710, in execute_tasks
File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 403, in _executetasks
File "R:\Streamer\src\adsk\dls\streamer\windows\platform.py", line 285, in create_launch_items
File "R:\Streamer\src\adsk\dls\streamer\windows\platform.py", line 366, in _manipulate_shortcuts
File "R:\Streamer\src\adsk\dls\streamer\manifests.py", line 807, in walk_external_references
File "R:\Streamer\src\adsk\dls\streamer\windows\platform.py", line 330, in __filevisitor
File "R:\Streamer\src\adsk\dls\streamer\manifests.py", line 62, in __next__
File "R:\Streamer\src\adsk\dls\streamer\manifests.py", line 44, in _manifestvalfor
File "R:\Streamer\src\adsk\dls\streamer\manifests.py", line 239, in _process_template_value
File "R:\Streamer\src\adsk\dls\streamer\utils.py", line 255, in __call__
File "E:\Jenkins\3P\PYTHON\3.7.6\WIN64_1\lib\string.py", line 132, in substitute
File "E:\Jenkins\3P\PYTHON\3.7.6\WIN64_1\lib\string.py", line 125, in convert
File "R:\Streamer\src\adsk\dls\streamer\manifests.py", line 228, in __getitem__
File "R:\Streamer\src\adsk\dls\streamer\configuration.py", line 728, in __getitem__
File "R:\Streamer\src\adsk\dls\streamer\windows\platform.py", line 1796, in __getitem__
File "R:\Streamer\src\adsk\dls\streamer\platform_base.py", line 104, in __getitem__
IndexError
CGBenner
@for_reg_arn
Welcome to the forum, and thank you for sharing the logs.
@RajkumarIlanchelian is this something you can help with?
Chris Benner
RajkumarIlanchelian
@for_reg_arn Our apologies for this experience. Can you please try the below?
1. Make sure that Fusion installer is not running in task manager
2. Go to C:\Users\user\AppData\Local\ DELETE folder Autodesk\
3. Do not use the same Fusion installer. Can you please download the installer again? (make sure that 360 is not found in the installer name)
4. Now install again
This should help get the full install done.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
