Fusion 360 hangs
Fusion 360 hangs
tomas.akinis
Observer Observer
Fusion 360 hangs
tomas.akinis
Observer
Observer
Noticed Several times that my Fusion hangs on changing scale. No error occure, just hangs on at this step and nothing can do. Need to end process in task manager 😞  > Waitting for respons not helps. Never responding even after long time of waiting.
Marco.Takx
Hi @tomas.akinis,
I've also seen some issues after rescaling a view.
Placing it new mostly goes better 🤔
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
jhackney1972
Please attach your MODEL ONLY of the model giving you issues.  Open in Fusion 360, select the Fike menu, then Export and save to your hard drive.  Attach to a reply post using the Attachment section.
John Hackney, Retired
tomas.akinis
Observer
Observer
Attached model.
Other times it hangs with another models, so, this happens not only with this particular model.
jhackney1972
I cannot understand why you attached a STEP file when you are working with a Fusion 360 model.  No matter, I can see no issues with changing the drawing scale repeated times.  I would suggest using the Repair option in the Fusion 360 Service Utility if this problem continues.
Marco.Takx
Hi @tomas.akinis,
I've also tested it on my end.
And hier also no issue.
Marco Takx
